13 years agoCan't use 2 pins together on a single IDC connector (Altera DE1 Development Kit)
Hi. I have a problem with using 2 pins together on a single IDC connector. I don't have signal on each of 2 pins of single IDC connector. If I use only 1 pin on a single IDC connector, I can ...
13 years agoIf I try to compile case C, on Quartus 12sp1, I get some warnings:
--- Quote Start --- Warning (275080): Converted elements in bus name "GPIO_1" using legacy naming rules. Make any assignments on the new names, not on the original names Warning (275081): Converted element name(s) from "GPIO_1[1]" to "GPIO_11" Warning (275081): Converted element name(s) from "GPIO_1[3]" to "GPIO_13" Critical Warning (169085): No exact pin location assignment(s) for 2 pins of 4 total pins Info (169086): Pin GPIO_11 not assigned to an exact location on the device Info (169086): Pin GPIO_13 not assigned to an exact location on the device --- Quote End --- I don't use the schematic editor, so I'm not exactly sure what's going on, but it looks like Quartus is renaming GPIO_1[11] as GPIO_11, and the later name does not have a pin assignment. My advice: stop using the schematic editor.
