CAlex
Contributor
2 years agoCan't set LoanIO by FPGA ,cycloneVsoc Dev kit
Hi, There is a IDC 2*7 on the board, the pins are HPS pins,here is the schematic Most of them are connnected to the HPS Bank7. In HPS settings, I set the GPIO 58,59,60 as loanIOs(5,7 ...
- 2 years ago
thanks for the reply , problem is solved, I sent the 313MHZ signal instead of 313KHZ, the GPIO pin with 3.3 LVTTL std dont have such high bandwidth.
When I set to 313KHZ the result is good.
Reguards
Alex
aikeu
2 years agoHi CAlex,
May I know if using the same pin as normal GPIO and is triggered by HPS, does it shows a normal digital signal?
Can try to loan with other pin as well to see if the same problem occured.
Aik Eu
- CAlex2 years ago
Contributor
Reguards
Alex
