Can't set LoanIO by FPGA ,cycloneVsoc Dev kit
- 2 years ago
thanks for the reply , problem is solved, I sent the 313MHZ signal instead of 313KHZ, the GPIO pin with 3.3 LVTTL std dont have such high bandwidth.
When I set to 313KHZ the result is good.
Reguards
Alex
Update:
If you are using the same dev kit and facing the same problem as I do,
please check the following setting: HPS sysmgr reg on LOANIO and GENERALIO settings.
If the J31 jumper is shorted.(So that my pins above can be connected to the HPS board).
With the old problem solved, a new problem occurred.
I set the LOANIO 60 as output and assigned it as a clk output(320KHz), yet through Oscilloscope I got a analog signal, which shocked me.
I changed the duty and the output changed with that, so the code has no problem.
But what I want is the digital signal.
