14 years agoCan't load design for PCIe tab in BTS with transceiver starter kit
Just got a Cyclone IV Transceiver Starter Kit, but can't get to the point I can access the PCIe tab in the Board Test System (BTS). Version 11.1.0 of BTS doesn't display a "Configure" menu, so ...
14 years agoHi Kamel,
--- Quote Start --- What I'm actually after is to use the PCIe connector on the Altera kit as a serial data generator --- Quote End --- In that case, ignore the BTS design. You do not need to do anything special to get the transceiver signals coming out the PCIe edge connector. Just instantiate an ALTGX, and ALTGX_RECONFIG, and reset logic, and you can transmit/receive over your SMA cables. While the above advice sounds easy enough, it might take you a while to figure out how to initialize the ALTGX logic correctly. The Cyclone IV GX handbook has figures with the required reset sequences, but its up to you to design and implement the controller. See if you can figure it out. If you have trouble, ask questions. Cheers, Dave
