AWann1
7 years agoCan't implement HSMC on CycV Soc Dev Board
Hello, I'm using the supplied project and golden_top .v files for the Cyclone V SoC board. I'm just writing out a memory file through the HSMC bus, using the already defined pins. However, I get t...
Rahul_S_Intel1
7 years agoGlad to know that problem is solved . Just for giving an debug steps, if you are encountering fitter error make the pin placement auto and see the quartus is passing , If it is passing, you can assume the design does not have issues
