AWann1
7 years agoCan't implement HSMC on CycV Soc Dev Board
Hello, I'm using the supplied project and golden_top .v files for the Cyclone V SoC board. I'm just writing out a memory file through the HSMC bus, using the already defined pins. However, I get t...
AWann1
7 years agoI did a little testing, if I remove that hsma_tx_d_p[0] line from the bus completely, the error just changes to the next signal in the bus. It says hsma_tx_d_p[1] can't be placed.
If I remove that one, it changes to hsma_tx_d_p[2], and so on until the last signal
