10 years agoCan't get C5G Control Panel v 1.0.2 to connect to Cyclone V GX Starter Kit board
I get a popup dialog box with the following message: please make sure quartus is installed! when I attempt to connect the Control Panel running on my Windows 7 PC to the Cyclone V GX Starter Kit boar...
10 years agoSo what you are saying is not to use the Control Panel? You have an entire chapter in your CG5 User Manual devoted to using it: this doesn't make any sense to me.
--- Quote Start --- Hi, Normally we will use the BTS or the QII to interface with the CV GX starter kit instead of using control panel. --- Quote End ---
