12 years agoCan't create workable controller for SRAM 512 kb (ISSI IS61LV25616AL) on Altera DE1
Hello all. I have a problem with SRAM 512 kb (ISSI IS61LV25616AL) on Altera DE1. My problem is: If i set memory address and writing data to memory cell with this address, after if i ...
11 years agoproblem is solved.
We have 16 bidireсtional pins for data writing/reading on SRAM 512 kb (ISSI IS61LV25616AL) on Altera DE1. And I define this 16 pins as "reg" type with "inout" direction in my verilog module:
module new_simple_controller
inout reg data_bidir,
But as I think - "reg" type can change value only inside verilog module. And this value can't be changed from outside. When I writed data to SRAM, this data writed to "reg". But when I readed data from SRAM, i only readed previous writed data from "reg" (but not data which readed from SRAM). Thanks to Shawn Gerber (http://www.youtube.com/watch?v=ubsreeqe8hw&list=uu2tvyj0h_2txv9oxqeha7uq - SRAM Controller in Verilog for Altera DE1 board). He sended me source code of his SRAM controller and I finded this mistake in my code. solution of this problem is following: 1) "Inout" direction for 16 SRAM data pins only "wire" type.
module controller_for_sram_is61lv25616al
inout wire data_from_to_sram_input_output,
2) Add three registers.
reg register_for_reading_data; // intermediate buffer register for reading data
reg register_for_writing_data; // intermediate buffer register for writing data
reg register_for_splitting; // register for disabling last "assign"
// if = 0 - disable last "assign" (switch last "assign" to high impedance state)
// (when we read data from bidirectional SRAM port - we can't write dada to this port)
// if = 1 - enable last "assign"
// (when we write data from intermediate buffer register "register_for_writing_data" to bidirectional port)
3) Reading from SRAM.
register_for_reading_data<=data_from_to_sram_input_output; // we read data, when last "assign" in high impedance state
4) Writing to SRAM.
assign data_from_to_sram_input_output = (register_for_splitting) ? register_for_writing_data : 16'bz; // last "assign"
Controller source code (controller_for_sram_is61lv25616al.v) and diagram of work (diagram_of_work.pdf) in attachment.
