scong4
6 years agocan't config Arria 10
I use a Arria 10 10AS048H4F34E3SG, set MSEL[2:0] to 011,VCC and VCCPGM = 1.8V. I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high ...
scong4
6 years agoThis is the circuit.
- ShafiqY_Intel6 years ago
Hi scong4,
May I know the connection of pins TCK, TDI, TDO? (no information in above picture)
Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2)
besides, do you used .jic file to program the FPGA?
When you convert to .jic, did you TICK both of this option?
Thanks..
- scong46 years ago
Hi WolfGang My flash device is EPCQL256F24IN. GND--| 1K | TCK -- 1 2 -- GND TDO -- 3 4 -- +1.8V TMS -- 5 6 -- +1.8V -- 7 8 -- TDI -- 9 10 -- GND | 1K | +1.8V This board modified from a old design , no change with the FPGA ciruit . So I use the same data file with the old design and write the data to the flash. I think the data is correct. Thanks WolfGang (Intel) Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. View/Answer or reply to this email Replying to can't config Arria 10 scong4 (Customer) Thursday, 2020年1月9日 PM3:10 [Image placeholder for fpgaconfig] fpgaconfig This is the circuit. WolfGang (Intel) Hi scong4, May I know the connection of pins TCK, TDI, TDO? (no information in above picture) Which flash device you are using?(i.e. EPCQ128, MT25Q, etc2) besides, do you used .jic file to program the FPGA? When you convert to .jic, did you TICK both of this option? [Image placeholder for jic both TICK] jic both TICK Thanks.. Thursday, 2020年1月9日 PM4:12 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as [email protected]. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums] - ShafiqY_Intel6 years ago
How about this "When you convert to .jic, did you TICK both of this option?"
cheers
- scong46 years ago
I didn't do this step , I use a flash image write the configuration data directly . Thanks
