scong4
6 years agocan't config Arria 10
I use a Arria 10 10AS048H4F34E3SG, set MSEL[2:0] to 011,VCC and VCCPGM = 1.8V. I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high ...
ShafiqY_Intel
6 years agoHi scong4,
Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM?
Noted: the nSTATUS signal low to indicate a configuration error.
scong4
6 years agoThank you for your reply!
I send my configration circuit to you . The nSATUS pin connects to a 10Kohm resistor .
And the power up is 0.9v->1.0v->1.8v .
shiping cong Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks
WolfGang (Intel)
Hi scong4,
View/Answer
or reply to this email
Replying to
scong4 (Customer) asked a question.
Wednesday, 2020年1月8日 AM8:43
I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high again . The configuration is fault , How can I find the problem ?
Shiping
WolfGang (Intel)
Hi scong4,
Thursday, 2020年1月9日 PM1:40
You're receiving emails when someone "Comments on my posts."
To change or turn off Forums email, log in as [email protected].
Are notifications about this post getting annoying? Reply to this email with the word " mute ".
For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html.
[Forums]
- ShafiqY_Intel6 years ago
Hi scong4,
I did not get your configration circuit.
where you send it? Is it to my private message or in this thread?
Regards.
WolfGang
