scong4
6 years agocan't config Arria 10
I use a Arria 10 10AS048H4F34E3SG, set MSEL[2:0] to 011,VCC and VCCPGM = 1.8V. I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high ...
ShafiqY_Intel
6 years agoHi scong4,
Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM?
Noted: the nSTATUS signal low to indicate a configuration error.
- scong46 years ago
Thank you for your reply! I send my configration circuit to you . The nSATUS pin connects to a 10Kohm resistor . And the power up is 0.9v->1.0v->1.8v . Thanks shiping cong Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks WolfGang (Intel) Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks View/Answer or reply to this email Replying to scong4 (Customer) asked a question. Wednesday, 2020年1月8日 AM8:43 can't config Arria 10 I use a Arria 10 10AS048H4F34E3SG, set MSEL[2:0] to 011,VCC and VCCPGM = 1.8V. I check the nStatus after power on ,it goes high for about 15 DCLK cycle, then goes low for several ms and goes high again . The configuration is fault , How can I find the problem ? Regards Shiping WolfGang (Intel) Hi scong4, Did you connect nSTATUS pin to external 10kOhm resistors to VCCPGM? Noted: the nSTATUS signal low to indicate a configuration error. Thanks Thursday, 2020年1月9日 PM1:40 You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in as [email protected]. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]- ShafiqY_Intel6 years ago
Hi scong4,
I did not get your configration circuit.
where you send it? Is it to my private message or in this thread?
Regards.
WolfGang
