12 years agocan't build example for Cyclone IV GX Kit
Hello! I've got Cyclone IV GX Transceiver Starter Kit. When I trying to build examples/board_update_portal/c4gx15_starter_bup.qpf I see following error: Error (12006): Node instance "c4gx15_fpga_bup_...
12 years agoYES!!! Thank you, I forgot to generate nios system! SOLVED! :)
At least I see in Wireshark that ethernet is working and DHCP discovers sent out. P.S. I'm also using Altera's competitor soft-CPU solution where approach is slightly different and in fact I'm newbie in Altera's SoPC.
