12 years agocan't build example for Cyclone IV GX Kit
Hello! I've got Cyclone IV GX Transceiver Starter Kit. When I trying to build examples/board_update_portal/c4gx15_starter_bup.qpf I see following error: Error (12006): Node instance "c4gx15_fpga_bup_...
12 years agoIf the design is based on SOPC Builder, you need to use SOPC Builder to "Generate" the files, and then compile the project in Quartus. The error from Quartus is indicating it can't find the SOPC Builder generated files (probably because you didn't do that step).
