Arthur1802
2 years agoCannot open MegaWizard to re-generate the FFT core provided by the article "Implementing OFDM modul
Hi, I want to implement the OFDM modulator and demodulator on the DE2-115 board. I use Quartus Prime Version 21.1.1 Lite Edition. I followed the article's instructions: Implementing OFDM Modulation...
SyafieqS
2 years agoDoes that IP is in IP catalog? I think you need license for that.
- Arthur18022 years ago
Hi, sorry for the late reply.
Is the IP you mentioned an FFT IP? If so then I can find it in the IP Catalog.
If not, could you tell me which IP is needed? And which Library does it belong to?
Thank you.
