MLei01
5 years agoCan we set tamper protection bit for volatile security key programming by using C5G on-board blaster
Hi , My customer wanted to confirm the following question, can you help?
I understand where you are coming from with respect to non-volatile programming.
However for our purposes, we are needing...
YuanLi_S_Intel
5 years agoHi,
Once tamper bit protection is enabled, you cant program volatile security key programming using Quartus Programmer.
You can program both volatile and non volatile security key using Quartus Programmer if tamper bit protection is not enabled.
Thank You.
