Sushmita
6 years agoCan Verification BFM IP example design (Quartus 16.1) be run on Quartus 18.1 version?
Hi, I want to run Verification IP BFM example design in qsys. It supports 16.1 version of quartus. I am using quartus 18.1 version with Arria 10 device support installed as required by the design. ...
sstrell
6 years agoThis is what I see when I click the link you posted:
But anyway, I'd try moving the files to a different location. Do you have administrator access? The files are in the administrator downloads folder. If you can't write the files, you can't enable the simulation option and you can't generate the files.
#iwork4intel
Sushmita
6 years agoOkay, i will try to move the folder and check once.
I will get back to you.
Thank you.
