OldMarty's avatar
OldMarty
11 months ago
Can Instantiation components be repeated easier??
Hi all,
When Instantiating multiple components, my U1,U2,U3 "adders" would be as follows:
    U1 : Adder
        Port map ( A => A,
                   B => B,
                   Sum => Sum);
    U2 : Adder
        Port map ( A => A,
                   B => B,
                   Sum => Sum);
    U3 : Adder
        Port map ( A => A,
                   B => B,
                   Sum => Sum);
Is there a way (when using IDENTICAL components) to state something like the following code?:
    U1,U2,U3 : Adder
        Port map ( A => A,
                   B => B,
                   Sum => Sum);
  • FvM's avatar
    FvM
    no it's neither legal nor meaningful VHDL syntax.
    You can refer to formal definition of instantiation statement in VHDL language reference IEEE Std 1076
     component_instantiation_statement ::=
       instantiation_label :
         instantiated_unit
            [ generic_map_aspect ]
            [ port_map_aspect ] ;
     instantiated_unit ::=
         [ component ] component_name
         | entity entity_name [ ( architecture_identifier ) ]
         | configuration configuration_name
    U1, U2, U3 are instantiation labels, there can't be multiple lables in an instantiation.
    Semantic-wise, it makes no sense to have multiple statements with identical port mapping. In this case, you are creating multiple drivers for signal Sum. Meaningful multiple instantiations will have at least some ports different.
    Generate statements can however compact your code
    genadders:
    for i in 1 to 3 generate
      U : Adder
        Port map (
          A => A(i),
          B => B(i),
          Sum => Sum(i));
    end generate;
