OldMarty
11 months agoCan Instantiation components be repeated easier??
Hi all, When Instantiating multiple components, my U1,U2,U3 "adders" would be as follows: U1 : Adder Port map ( A => A, B => B, Sum => Sum)...
FvM
11 months agoHi,
no it's neither legal nor meaningful VHDL syntax.
You can refer to formal definition of instantiation statement in VHDL language reference IEEE Std 1076
component_instantiation_statement ::=
instantiation_label :
instantiated_unit
[ generic_map_aspect ]
[ port_map_aspect ] ;
instantiated_unit ::=
[ component ] component_name
| entity entity_name [ ( architecture_identifier ) ]
| configuration configuration_nameU1, U2, U3 are instantiation labels, there can't be multiple lables in an instantiation.
Semantic-wise, it makes no sense to have multiple statements with identical port mapping. In this case, you are creating multiple drivers for signal Sum. Meaningful multiple instantiations will have at least some ports different.
Generate statements can however compact your code
genadders:
for i in 1 to 3 generate
U : Adder
Port map (
A => A(i),
B => B(i),
Sum => Sum(i));
end generate;
