AZeli
7 years agoCan I use USB Blaster w/ Cyclone 10 LP Eval Kit?
I am trying to connect USB Blaster to Cyclone 10 LP eval kit directly. Is it possible? i cannot connect to the EPCQ device.
AnandRaj_S_Intel
7 years agoHi AZeli,
we can connect USB blaster to Cyclone 10 LP eval kit but.
- USB Blaster Programming J2 Header uses JTAG mode only.
- To connect it to EPCQ we need to use build in USB blaster using USB connector J17.
Anand
- AZeli7 years ago
Thank you for the response.
I connected a USB blaster to J2 and scanned the chain. I see two devices - the FPGA and a virtual device. I didn't see the CPLD on the chain, which led me to suspect that there is a separate JTAG chain for it. I think I also figured out the EPCQ already.
Is there a way to eliminate the virtual device from the chain?
- AnandRaj_S_Intel7 years ago
Hi AZeli,
Yes, can eliminate the virtual device from the chain using DIP switch SW1.
SW1.4 Logic 0 = Vitual JTAG Bypass
Logic 1 = Vitual JTAG Enable
Anand
