10 years agoCan I use the BEMICRO MAX 10 to program the MAX 10 FPGA Evaluation Kit?
Hello everybody Taking a look to the schematic of the Arrow BeMicro MAX 10 tool I could see a connector labeled "USB_Blaster_JTAG" (J7). Then looking for images of the tool I can see that this ...
10 years agoYour pinout on the top side shown in the image above is correct.
You just need a 2x5 header to solder to the edge. Then use a 2x5 ribbon cable to connect to the target board. The target board has to supply a voltage 2.5 or 3.3. CPLD bank2 would switch to that voltage ... The voltage is called USB_Blaster_power This is how i use
