YUVRAJSHAH
6 years agoCan I use a single code on different FPGA boards.
can I use same code on different FPGA like for example can I use same code on stratix 10 & Agilex. or do I need to change the code or rewrite the whole code. thanks & cheers yuvraj shah
KennyT_altera
6 years agoAdditional, you will have to look into the timing closure once you migrate the code. Since the architecture are different, there will be code optimization need to be done from your side. My suggestion is to look into the class available here:
https://www.intel.com/content/www/us/en/programmable/support/training/course/is10perf.html
