NFish4's avatar
NFish4
7 years ago
Can I have the sources for System Max V on Arria 10 dev kit board (U16)?
the example on rocketboards site has POF file only
  • AR_A_Intel's avatar
    AR_A_Intel
    Hello Welcome to INTEL forum. May I know the reason you request the sources for System Max V. Could you help elaborate more on your request.
  • NFish4's avatar
    NFish4
    Since all peropheral connected to A10 through the MAX V, I would like to know how it is connected to these peripheral.
    to be more specific I would like to connect UART DB9 (J35) to A10 (U23).
    So I need Either a document to suggest the pins in/out of A10 (U23) to connect this peripheral.
    thanks
    Noam
    AR_A_Intel
    Hello Regarding you request for sources System Max V, I will refer this to board team member. Please give me some time and I will get back to you with an update.
    AR_A_Intel
    May i know what is the application with UART? Based on my understanding, You may connect it to another I/O pin on the FPGA
  • NFish4's avatar
    NFish4
    In our project we would like to buildin parallel to the HPS also NIOS2 with peripherals such as UART (different than the one connected for linux J10 UART1).
    So the next candidate can be J25 DB9. In schematics J25 connected to Max V.
    How is it connected to U23 A10? to which pins?
    thanks,
    Noam
    AR_A_Intel
    Hello Sir, Yes, you can connect to any pin to the HPS.
