Caesar Cipher
I am trying to create a simple Caesar cipher but the same issue keeps arising. I am sure that there is a few issues with my code. I am just starting out VHDL. The code is below any help would be great.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
entity caesar is
Port ( clk : in STD_LOGIC;
enableSwitch : in STD_LOGIC;
SW : in STD_LOGIC_VECTOR (7 downto 0)
end caesar;
architecture Behavioral of caesar is
type counterType is array (7 downto 0) of STD_LOGIC_VECTOR(5 downto 0);
signal counter : counterType;
signal clkSignal : STD_LOGIC_VECTOR( 2 downto 0 ) := "000" ;
signal clkDivider : STD_LOGIC_VECTOR( 15 downto 0 ) := "0000000000000000" ;
shared variable clkSignalHolder : unsigned(2 downto 0) := "000"; -- Seems prudent to ensure all else is based on this
begin process (clk) is
begin
if ( clk='1' and clk'event) then
if enableSwitch='1' then
clkDivider <= clkDivider + 1;
end if;
if clkDivider = "1111111111111111" then
clkSignal <= clkSignal + 1;
end if;
end if;
clkSignalHolder := TO_INTEGER(unsigned(clkSignal));
if RISING_EDGE(SW(clkSignalHolder)) then
counter(clkSignalHolder) <= counter(clkSignalHolder) + 1;
if (counter(clkSignalHolder) > "011001") then
counter(clkSignalHolder) <= "000000";
end if;
end if;
if RISING_EDGE(enableSwitch) then
for I in 0 to 7 loop
counter(I) <= counter(I) + 13;
if (counter(I) > "011001") then
counter(I) <= counter(I) - 26;
end if;
end loop;
end if;
end process;
1 Reply
- Vicky1
Hi Ciara, Could you please check with declaration of shared variable using 'integer' instead of unsigned? Please let me know if you have any concern. Regards, Vikas
