Building uboot for cyclone V SoC
- 1 year ago
Hi Snehal
Just to update the forum case.
The missing steps from the RBO page are the steps below:
1.Step to convert the sof to rbf. You could use the command below to convert the sof.
quartus_cpf -c -o bitstream_compression=on soc_system.sof soc_system.rbf
2.Missing u-boot.scr could be gotten from the gsrd page.
https://releases.rocketboards.org/2025.03/gsrd/c5_gsrd/u-boot.scr
3.Place both rbf and the u-boot.scr in the sdcard partition 1 (sdfs)
Jingyang, Teh
Hi
Could you also try these packages:
sudo apt install make
sudo apt install gcc
sudo apt install binutils-doc gcc-multilib autoconf automake libtool flex bison gcc-doc gcc-11-multilib gcc-11-doc gcc-11-locales
sudo apt install ncurses
sudo apt install ncurses-compat-libs
sudo apt-get install gcc-arm-linux-gnueabihf
Jingyang, Teh
I tried but same error.
I tried booting using files generated on another system, getting attached error, can you please help.
