Building uboot for cyclone V SoC
- 1 year ago
Hi Snehal
Just to update the forum case.
The missing steps from the RBO page are the steps below:
1.Step to convert the sof to rbf. You could use the command below to convert the sof.
quartus_cpf -c -o bitstream_compression=on soc_system.sof soc_system.rbf
2.Missing u-boot.scr could be gotten from the gsrd page.
https://releases.rocketboards.org/2025.03/gsrd/c5_gsrd/u-boot.scr
3.Place both rbf and the u-boot.scr in the sdcard partition 1 (sdfs)
Jingyang, Teh
Hi
I tried the steps and able to build uboot successfully.
Could you try setting :
export CROSS_COMPILE=arm-none-linux-gnueabihf-
Also check the path for the compiler to be set properly:
tar xf gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
rm gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
Further more the cv_bsp_generator.pt needs to run using python2 instead of python3
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH
Jingyang, Teh
