Building DDR controller Example Design - Component DDR over Agilex board
- 1 year ago
Hi Madhur,
Please download the DK-DEV-AGI027-RA/RA-B installer package from the devkit website.
DK-DEV-AGI027-RA/RA-B (v24.3.1 or higher)
The serial number that you have shared is belong to this devkit.
Agilex™ 7 FPGA I-Series Development Kit (Production 2x R-Tile & 1x F-Tile)
(Power Solution 2)
DK-DEV-AGI027-RA AGIB027R29A1E1VB 8100505 Please try to generate the example design based on this devkit and DDR4 setting from this devkit.
Or you can use the existing design in this devkit file.
You also may test the devkit with BTS application but need to use with Quartus version 24.3.1.
From the BTS, you can quick check if there is any error during read and write process of the DDR4 interface.
Adzim
Hello Adzim
After some modification in the CAS latency of DRAM controller, I am able to Create Memory connection in the System Console.
But still calibration is failing, with an error code "L1 PASSING WINDOW NOT FOUND".
Here is the memory configuration being read in the System Console.
Can you figure out something out of this info.
Note: I am using this board setting DK-DEV-AGI027-RA (where the DDR component lies on bank no. 2B and 2E.) and pin mapping as per this schematic (https://www.intel.com/content/dam/support/us/en/programmable/support-resources/bulk-container/support/boards-kits/agilex/agilex-agi027-devkit-schematic-reva1-apr2021.pdf)
regards
Madhur
