Building DDR controller Example Design - Component DDR over Agilex board
- 1 year ago
Hi Madhur,
Please download the DK-DEV-AGI027-RA/RA-B installer package from the devkit website.
DK-DEV-AGI027-RA/RA-B (v24.3.1 or higher)
The serial number that you have shared is belong to this devkit.
Agilex™ 7 FPGA I-Series Development Kit (Production 2x R-Tile & 1x F-Tile)
(Power Solution 2)
DK-DEV-AGI027-RA AGIB027R29A1E1VB 8100505 Please try to generate the example design based on this devkit and DDR4 setting from this devkit.
Or you can use the existing design in this devkit file.
You also may test the devkit with BTS application but need to use with Quartus version 24.3.1.
From the BTS, you can quick check if there is any error during read and write process of the DDR4 interface.
Adzim
Hello Adzim
I generated the SOF file using the example design shared over below link https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/agi027.html, but that didn't work.
And also I checked the development kit serial number, please find below the requested details.
OPN# DK-DEV-AGI027-RA
Serial number: AGIPCIe8100537
TA#: N2415-001
I even tried to change the DDR parameters as the example design you shared keeping the board setting as DK-DEV-AGI027-RA (where the DDR component lies on bank no. 2B and 2E.) but still same issue occurs (as described in original post).
Please suggest if I need to change any other setting.
regards
Madhur
