Building DDR controller Example Design - Component DDR over Agilex board
- 1 year ago
Hi Madhur,
Please download the DK-DEV-AGI027-RA/RA-B installer package from the devkit website.
DK-DEV-AGI027-RA/RA-B (v24.3.1 or higher)
The serial number that you have shared is belong to this devkit.
Agilex™ 7 FPGA I-Series Development Kit (Production 2x R-Tile & 1x F-Tile)
(Power Solution 2)
DK-DEV-AGI027-RA AGIB027R29A1E1VB 8100505 Please try to generate the example design based on this devkit and DDR4 setting from this devkit.
Or you can use the existing design in this devkit file.
You also may test the devkit with BTS application but need to use with Quartus version 24.3.1.
From the BTS, you can quick check if there is any error during read and write process of the DDR4 interface.
Adzim
Hello Adzim
I compared the example design in the link you shared with my design. I found the pin mapping to be very different.
I was referring to the below schematic.
While the example design in your link https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/agi027.html refer to different schematic (attached in board design files)
Please confirm which one is correct.
And yes I have enabled "EMIF Debug Toolkit in EMIF IP" in the IP and I am using Quartus version 23.4.3.1.
Note: in the meantime I will generate the SOF file using example design you shared and test it on the board.
Madhur
