10 years agoBoard Extension for DE1-SoC
Hello, I'm looking for a solution how to connect to make "available" the DE1-SoC board for sensor boards with limited number of contacts, e.g. from here: http://store.digilentinc.com/pmod-exp...
10 years agoYou mean "nest" at other side of 40-pin ribbon cable several "low-pins" breakout headers connected to several let say sensor modules ?
In this case power problem arises: each of these two 40-pin headers disposes only 2 PWR and 2 GND (please see the snapshot of schematic fragment). So only 2 sensor modules per header can be connected this way. I envisaged anther solution, like that realized for Zync MicroZed board: FPGA board is inserted into I/O Carrier Card that provides access to 12 Pmod-based external modules (please, see the snapshot below). https://s9.postimg.org/ezj4a0d6z/gpio_header_layout.jpg (https://postimg.org/image/ezj4a0d6z/) https://s9.postimg.org/5ybyz010b/micro_zed_with_io_carrier_card.jpg (https://postimg.org/image/5ybyz010b/)
