14 years agoBITEC HSMC DVI I/O I2C Confirmation needed.
Hi, I am using the Bitec DVI HSMC Card for display purposes. I went through the schematics(Please find the attachment) and found that the I2C signals HSMC_SDA and HSMC_SCL are not connected to ...
14 years agoHi sneha,
Thanks for the confirmation. Could you please tell me whether the config I am using on the pins is right/You have used the same thing ? \PD is set to '1' ISEL is set to '1' CTL1 is set to '0' CTL2 is set to '0' CTL3 is set to '0' And could you please let me know any other constraints you used in the .qsf file and .sdc file ?
