Best way to archive an entire project, logic, qsys, and NIOS software
I am using Quartus Prime 18.1 Lite. I have a project that contains VHDL Logic, a Platform Designer Qsys system, and NIOS Software in the SBT for NIOS. What is the best way to archive the entire project so that I can be resurrected at a later date without a lot of effort?
- sstrell
From the Project menu, select Archive Project. You can quickly create a .qar file (Quartus archive) or click Advanced to customize what is put in the .qar. That will archive the hardware. For the software, I don't know if SBT has an archiving utility, but you can just zip up wherever you have selected for the location of your application and BSP projects.
#iwork4intel
- WShep1
Contributor
Thanks for your response.
I take it that there is not one method to archive both the hardware and software of a project. Is this correct? Do the hardware and software need to be archived separately?
- KennyT_altera
You can refer to here https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03312009_660.html However, for platform designer, you may zip it because some of the files might not able to archive if you have a different directory than your project directory. - KennyT_altera
Is there any update?- WShep1
Contributor
I closed this SR a couple of days ago. Thanks for your assistance.
