14 years agobemicro windows 7 64bit programmer
Hello, I am using the bemicro board from arrow. I get everything to compile, I have all the drivers. However, when I click on the programmer button and click hardware setup, the only option that...
14 years agoHi!
I have the same problem, it will not work on 64-bit win7. You should try with a virtual machine. I have made it work on a 32 bit win xp vmware virtual machine, and it is fine now. Good luck, if you have any questions just ask it! :)
