14 years agoBeMicro SDK - how to access SD card
updated 7th november - change title from BeMicro SDK - how to access SD card to bemicro sdk - how to make the web server run from epcs memory Hi All The reference board I am u...
14 years ago"from slscorp (http://www.slscorp.com/ip-cores/memory/sd-host-controller.html) i can get an evaluation....i assume that all i need is the driver as the controller is built into the hardware design"
not true, the reference configuration does not contain sd controller... So in order to get access to the SD card, you have to update the FPGA design....licence a trial of the mobile DDR controller and licence a trial of slscorp SD controller, place that in the design or use SPI bus as in the linux example above). :(
