14 years agoBeMicro SDK - how to access SD card
updated 7th november - change title from BeMicro SDK - how to access SD card to bemicro sdk - how to make the web server run from epcs memory Hi All The reference board I am u...
14 years agoThanks nekojiru
I already know about the linux port and have tried it...but I can not use linux for my application.... I'm looking at ucosii for the operating system.... From slscorp (http://www.slscorp.com/ip-cores/memory/sd-host-controller.html) I can get an evaluation....I assume that all I need is the driver as the controller is built into the hardware design- Software Drivers
- Custom HAL Driver for accessing SD Card (object code)
- Nios II Sample Applications
- FAT (16/32) File System (RockBox)
