9 years agoBeMicro Max 10 Board - LED Blink Project Using Quartus Prime 16.0.0 Lite
Hello, I am creating my first LED Blink project using the BeMicro Max 10 FPGA Kit. I am following an example from YouTube that uses a previous version of Quartus 15.0, and the code is written ...
9 years agoHello,
You can set the TOP file in Assignments / settings / general / and there is a field in the dialog box where you can select the top level entity. If you start from scratch you need to select the type of FPGA you are using you can do this in Assignments / Device and you need a pin configuration as well. The simplest way to get this is to open and existing configuration and open pin planner, there you can export an existing pin configuration. To import the pin configuration in your new program use assignments / import assignments. Do not go to pin planner to import assignments in your new configuration. Best Regards, Johi.
