14 years agoBemicro kit - embedded lab issues
I am getting down to the end of the embedded lab exercise. It looks like there is documentation conflict with what the lab says and what I see on the NIOS Eclipse software. Additionally, I get ...
14 years agoHi, kdf5036
O.K, I found 2 (cryptic) notes I made back in December which is the last time I fired up the kit. # 1 You have to exit Nios II system after a rebuild before you see RUN AS , NIOS # 2. I got this message: Target Connection]: System timestamp mismatch - connected: "1321331565", expected: "1322117462". And then I couldn't run the program until I disabled the Timestamp check in the debug dialog window. I'll see if there is anything else.....but now that I see my notes, I do recall that exiting and restarting the Nios II s/w seemed to solve the problem.
