17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years agoI am not sure I did it right as my results really did not work.
In the project I compiled I am able to flash the FPGA just fine with the results and it works. I added another file to the project with a JIC extension as a Serial Bitstream File. (I think I am missing a step here because next I compiled). I compiled and it finished successfully. Then in the programmer I Attached Flash Device. Added my jic file as its source and told the programmer to flash and it fails at 0%. Is there anything special about making Quartus II put out bitstreams so I can have this run my code on start up rather then the default flashed bitstream. I did back up the factory JIC and will keep it as it is neat. That worked perfectly.
