17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years ago --- Quote Start --- On Reinstall I used version 11.0sp1 Build 208. I really thought I had 11.1SP2 but it isn't this time. I am going to install driver from 11.0 and hope it makes a difference. Will let you know. --- Quote End --- Thanks. --- Quote Start --- Files and versions now match yours. Now it actually shows the blaster. --- Quote End --- That sounds encouraging. --- Quote Start --- I do apologize for my obstinance earlier. --- Quote End --- No worries :) --- Quote Start --- I see that you are right it was a driver issue. I have no idea why the newest has a defective driver and the old "working" version didn't. --- Quote End --- Yeah, what a PITA. --- Quote Start --- So if I understand it correctly if I have a design placed etc for just the FPGA it should actually process without the risc chip and the ram? --- Quote End --- Yep. I use the BeMicro for the FPGA. I could care less about the DDR, ethernet, etc. The 80-pin edge connector can be used to interface to a protoboard (Arrow list it). I use that interface. Cheers, Dave
