17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years ago --- Quote Start --- Sorry. What I was doing is using FPGA to pocess some data but the data resides on a different computer. The TCL script seems to operate properly just will not connect. Disable Firewall and it works. I had hoped not to branch into network connections until I had the local through a loopback worked out. Sadly I have 7 Home Premium. No Telnet. Test from XP computer may let me know something. Firewall on or off I can not telnet to port 1309. --- Quote End --- This is a very confusing description. I think you are mixing up several issues here. Perhaps you could summarize what works and what does not, eg., you have a hardware machine with Win7 that connects to the hardware (the USB-Blaster on a BeMicro-SDK), and you are trying to connect a remote machine (WinXP) to that hardware server. Hardware checks; Under Win7 does jtagconfig and the Quartus programmer see the USB-Blaster correctly? Under WinXP, can you connect to the remote jtagserver? The first check tells you the hardware is setup ok, the second check relates to networking. Cheers, Dave
