17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years agoCurrently ennumerated as 6001. I was afraid of that. Likely this means it is a 64 bit edition issue with the Web Edition. You are not using the Web Edition so yours likely will work fine. I have version 11.1 sp2 Build_259 I am going to guess that this is high enough. After reviewing my initial post I do see that I mistakenly typed 11.0 so for that it would be an upgrade. I really should have copied it rather then typing it by hand.
Link you recommend starts wrong service is running and does not stop for me. am trying the seperate programmer now. I can hope this will work. Thanks for your help EDIT: Stand Alone Programmer failed. Some old drivers I found that are supposed to fix it need a reboot and disable diver signature check. Is that the problem with the 11.1 drivers? Edit EDIT: Driver signature check disabled. Programmer still sees no hardware. It is strange.
