17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years agoThe Microtronix download has an example in the examples folder named bemicro_socket and bemicro_socket_bsp. Merge these files into your NIOS project as they are like the simple socket server template in NIOS but have the network_utilities.c file modified to work with the BeMicro board. Or, you can use the NIOS simple socket server template and copy the network_utilites.c file from Microtronix into that project.
When you build a project from the template, make sure you start NIOS as administrator or the project won't build correctly.
