17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years agoAnother good option is to turn on the debug printout. Right click in your BSP project and select NIOS II then BSP Editor. Go to the Main Tab, Settings>Advanced>hal>log_flags and log_port. Set Flags value to 1 and Port value to jtag_uart.
Also, under Settings>Common>hal make sure the sys_clk_timer is set to sys_timer and the timestamp_timer set to high_res_timer. After changes, make sure to Generate, Save and then right click on your bsp project and go to NIOS II>Generate BSP.
