17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years agoHi, Dave
--- Quote Start --- Hi Daniel, Ok. I'm traveling this week and don't have my BeMicro with me. I'd like to check there are no synthesis warnings before I send you the code. Which version of Quartus are you using? --- Quote End --- No problems, I'm not in a hurry with this. I'm using Quartus II 11.0. --- Quote Start --- Did you test the above procedure works for you? Can you get characters to echo? If so, you can create an SOPC system containing a NIOS processor and regular UART and connect that to the RX/TX pins. Sounds like you might have had a logic error and your logic was synthesized away to nothing. Try and implement the UART loopback and enable the VCP. That way you'll have made some progress. --- Quote End --- I haven't tried this yet. All I have done was that tutorial, up to that part. Later today I will test the procedure you described. I will be more alert to logic errors this time. Thanks, Daniel K. Franch
