17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
15 years ago --- Quote Start --- Hi I was wondering if anyone here that's been using their bemicro has made any use of the 80 pin edge connector? Would you know of an 80 pin connector that would slip onto the end of the bemicro from which I could run wires from? I would like to run pwr and assorted inputs to the brd through this connector and run control signals out. Thanks... Mike --- Quote End --- I've made a couple of boards for the BeMicro - a simple I2C adapter with onboard EEPROM and buffer, and a more complex board with optically isolated ADC's and digital I/O. The connector is a Samtec MEC6-140-02. You can get samples of it directly from them. The only trick is that the right-angle and vertical connectors have different alignment pin locations.
