12 years agoBeMicro CV - Qsys starter project?
I give up: after much googling, I'm unable to find any starter Qsys-based projects for the BeMicro CV. Is anybody aware of anything I might be overlooking? I was hoping for NIOS+DDR3 Hard...
11 years agoWhen things "don't work", the first thing you should do is to run the design in the Modelsim simulator.
Its not too hard to get the BeMicro-CV working with a DDR3 model. The BeMicro-CV hard-memory-controller has a bug in the resets. The code I posted here does not have the bug, but I submitted another zip file showing the issue as an Altera Service Request. Send me a direct email message (to my forum name) and I'll send you that zip file if you want it as a starting point. It shouldn't be hard to get your design working in simulation. If the design simulates fine, but does not work in hardware, then at least you know the problem is not in the IP you are working with. Cheers, Dave
