14 years agoBCLK on WM8731
Hi , I am trying to grab incoming ADC data and also sending out data to DAC on WM8731. Now the datasheet says the max clk for bclk is 20Mhz , and the toggle btw L and R channel should be 1/fs...
14 years agoit seems I was wrong above. I copy from the datasheet:
"in slave mode, DACLRC and ADCLRC inputs are not required to have a 50:50 mark-spaace ratio. BCLK input need not be continuous. It is however required that there are sufficient BCLK cycles for each DACLRC/ADCLRC transition to clock the chosen data word length..." So, ADCLRC doesn't need to be fixed... cheers g
