11 years agoBasic Question aout I/O Pins on MAXII
Hi guys! I'm relatively new to FPGA's and CPLD's. I have successfully used and programmed a Cyclone V dev board in university, so i understand the basic principles of Quartus 2. Now I wanted ...
10 years ago --- Quote Start --- Yes, I would not have created a new project ;) but thanks for making clear that I only need to change the .bdf file! Can you tell me a resource where I can read and understand exactly what the different files and steps in the process do? For example the "Start Analysis & Elaboration".. Best, Adrian --- Quote End --- Adrian, There are Design Guidelines documents that are a good read. An example is this one: https://altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/m10_guidelines.pdf Each part has its own, but it helps get an idea of the "recommended" flow for design and the issues that can arise. For the general process and what each step does, I'd work through a few of the examples that are available online or provided with Quartus. The Quartus II manual has everything, but it's also not the best reading. Hope this helps.
