11 years agoBasic Question aout I/O Pins on MAXII
Hi guys! I'm relatively new to FPGA's and CPLD's. I have successfully used and programmed a Cyclone V dev board in university, so i understand the basic principles of Quartus 2. Now I wanted ...
11 years ago"If I want to make changes in the .bdf file and program them into the hardware, do I run through the exact same steps again?"
Regarding this Q, if any changes done to the bdf file which does not involve pin location change, you can just edit bdf -> save -> rerun compilation. You would not need to create project, assign IO or create top level again.
