Bare metal application does not work.
Hi everyone ( once again ),
I have been on this community from the first day I bought my board ( Atlas-SoC). With lots of effort and many helpful information from here, I managed to load everything and now I just need a simple bare metal application in C to test.
So I have made a simple code to send a number on the LEDs ( for example, I display number 13 in binary on my LEDs ). Here is my step
- Plug in the SD card and stop the autoboot. I plan to use uboot and uboot script but now I only have uboot so I will command everything by hand
- Configuring FPGA part by using command fatload to copy the .rbf file and fpga load to load the FPGA
- Enable the bridge by bridge_enable_handoff
- Then I use the debug tool in EDS-SoC with my LED.axf in Application on host to download field and the directory to synthesis folder in Add peripheral description files from directory field
- Debug and the LEDs displays the number 13.
As we can see that the debug works fine with my code, then I enable my 30 day-license to be able to use fromelf.exe tool in order to convert to .bin file. After having my bin file, I copy it to SD card, plug into the board and follow the same way I did.
After enable the bridge, I did
fatload mmc 0:1 0x00100040 led.bin
go 0x00100040On the Putty display
## Starting application at 0x00100040 ...And it hangs there and none of any LEDs is lighted up.
I have followed some workshop on rocketboard ( that how I got those step as you can see ) and read many tutorial. I have tried all of best and I apology for asking so much on here in every step I made ( I'm kinda newbie and I have learnt a lot until now ).
I hope I can have some clues from you guys !
Thanks in advance.
P/s : Here is my code
int main()
while (1)
alt_write_byte(0xff200000,13); // h2flw address is 0xff200000 and led offset is 0x0
return 0;
}1 Reply
- DChau5
Update the situation for those who may get into this situation:
After checking the linker script, I found out the RAM is initialized from address 0x100000 not 0x00100040 as I thought. From then, you can modify your starting address of your code.
BTW, so sorry for not paying much attention to what I am doing. Cheer !
