AVST Booting of Arria 10 SoC using parallel flash connected to MAX10
Dear Ma'am/Sir,
In our design we are using Arria 10 SoC, also we have max10 FPGA.
Can I boot the configuration file from the parallel flash which is connected to the MAX 10 FPGA to the Arria 10 SoC using the AVST booting.
While referring in the Arria 10 Boot User Guide, they are mentioning only Booting from MAX 2 and MAX 5. So, my question is like whether there are issues if we use MAX10.
In Stratix 10 SoC, they have mentioned the MAX10 FPGA for the same thing.
- EBERLAZARE_I_Intel
The Avalon-ST configuration scheme (AVST) is the fastest configuration scheme for Intel Stratix 10 FPGA and on-wards, in which it replaces the FPP mode in previous device families.
So it is not supported in the Arria 10, you may compare the max data rate of the configuration schemes that are already availabe for Arria 10:
Do you have any further questions?
- Sivakumar_S
First of thanks for the reply.
I have one more doubt for FPP mode also, can we use MAX10 for reading from parallel falsh and configuring the Arria 10SoC.
Wherever I am searching I am getting only Max v or max 2 series.
Here in this link also at last (MAX Series Configuration Controller Using Flash Memory white paper ) they have not mentioned Max10
https://www.intel.in/content/www/in/en/support/programmable/support-resources/configuration/cfg-fpp.html
So can we use max10 FPGA for FPP configuration.
I hope that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
